Simplest is to solder them all to a grounded copper trace and cover the top and bottom of the board around them with a thin polystyrene sheet to make them all track thermally. No need to heat them, just keep all at the same temperature, and make sure all are from the same production batch, which probably will mean ordering 50 or so and matching them for resonant frequency using a simple oscillator. May take a while to find the 5, as they will have to be kept in an isothermal enclosure and tested individually whilst not heating or cooling them.
