Yes and no.
Some are special, others are not.
Some are designed in such a way that their inductance and capacitance does not change with usage, eg if wires twist, inductance will stay the same. Others are designed with this in mind AND a kelvin connection, right at the tip of the tweezers. Some are characterized to be flat across a typical meters measurement frequency range.
On the other hand, some are as you have said, just tweezers with wire on them.
