Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Homebrew antenna analyzer for 1.2 ghz
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Homebrew antenna analyzer for 1.2 ghz (Read 768 times)
Cubbie
Contributor
Country:
on:
March 07, 2020, 05:58:45 am »
I'm building one because I like to homebrew. It will cover 600 Mhz to 1600 Mhz assuming I ever get this voltage controlled oscillator to work. Right now there is no output. I am using a Z-comm V502ME01 which is a 600 to 1600 VCO.
5 volts B+ 1-21 volts tuning and 50 output at 5 Dbm. I have worked with microstripline before so I'm pretty sure that is correct. Also I'm outputting into a Mar-3 MMIC. The one thing I do not understand is the loop filter example on the tuning voltage line. It is shown in a application note. No values are given because I'm pretty sure it is frequency dependent. I thought loop filters were used in PLLs not VCOs? Is a loop filter really needed? Thanks for any ideas.
https://www.zcomm.com/wp-content/uploads/2014/06/AN-102.pdf
Last Edit: March 07, 2020, 08:14:33 am by Cubbie
Logged
thinkfat
Supporter
Country:
This is just a hobby I spend too much time on.
Re: Homebrew antenna analyzer for 1.2 ghz
Reply #1 on:
March 07, 2020, 07:28:57 am »
If you don't build a PLL, or any other kind of loop, there is no loop and hence no loop filter.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
