Author Topic: FFT Software  (Read 3640 times)
Offline yramguTopic starter
FFT Software
« on: May 09, 2015, 05:34:16 pm »
Hi everyone,
I’m opening this topic to share a piece of PC software I wrote recently: an FFT tracer.
I designed it originally to help myself at work, where I wanted to analyze the frequency content of the output signal of an accelerometer. I first began to look for a simple (that part is important) software on the internet but couldn’t find anything I deemed suitable (either too complex/ not adapted to my needs) so I decided to design my own. I started by looking for a simple C FFT library and stumbled upon KISS FFT, which looked nice. I developed my own code under codeblocks and was doing all the tracing “manually” under Excel. When I got to a working code I decided to develop an interface to it, under Visual C++. I understand it may not be the best option, but I’m not a professional programmer so I didn’t want to spend too much time on it.
I could also have developed under linux but I don’t like Linux  >:D
Anyway as this is my own personal work (I developed it entirely at home), I decided I would share, may it be useful for somebody else.
Here are two links:
1 - The software : https://mega.co.nz/#!Ocl1kTLT!UWJPnSbFlhzuKuqJxD2BpKcpZ5hGxOR6kV5ZEzV6C1Q
2 - The english "manual", with screenshots and description of the software : https://mega.co.nz/#!6VcgHJTT!RGGWD4s1kuatzBRojYJt6ERFU5n0Q0wp9LbMRHlo-68
I tested it under XP/7/8 and it works fine.
Let me know what you think  ;)
Offline dom0
Re: FFT Software
« Reply #1 on: May 09, 2015, 06:55:51 pm »
- You might want to adhere to the LGPL license that comes with ZedGraph (that is, you need to put a notice somewhere  in your program and/or the README that you're using ZedGraph and that it's LGPL'd)
- You're distributing a debug build (~500 kB download overhead)
- No source code, so I won't run it
Online Alex Eisenhut
  • Place text here.
Re: FFT Software
« Reply #2 on: May 09, 2015, 07:46:40 pm »
LTSpice
open waveform
do fft?
Re: FFT Software
« Reply #3 on: May 09, 2015, 08:21:53 pm »
You're right, I'll add a readme for zedgraph and KISS FFT
Nope, it's the release build
Fair enough. At the beginning I wanted to release the source code but quite frankly it's such a mess (I developped for myself so I didn't put any effort on writing "clean" code) I don't think it would be of any help. I can publish it if people want it though.
LTSpice
open waveform
do fft?
I'm not a user of LTSpice, didn't know you could do that^^. Then again I didn't tell the whole story: I was also looking to implement an FFT algorithm in a microcontroller for a future project and that's why I began working with KISS FFT. Then along the way I decided to write my own PC software based on it. Just a pretext to work with the library  ;)
Offline dom0
Re: FFT Software
« Reply #4 on: May 09, 2015, 08:39:58 pm »
Well, you're shipping the .pdb file, that effectively turns it into a debug build.
Re: FFT Software
« Reply #5 on: May 09, 2015, 09:05:14 pm »
Yep, don't know why but it keeps generating the .pdb file even when configured in Release mode. Deleting it doesn't seem to change anything, the program still works.
Offline T3sl4co1l
    • Seven Transistor Labs
Re: FFT Software
« Reply #6 on: May 10, 2015, 04:01:51 am »
For audio (WAV) use, I've used AnalFreq ("The Unfortunately Named Spectrum Analyzer Tool" :-DD ).  NO idea if that's free, or too special-purpose, or...anything.
A more heavy-weight but general-purpose solution might also be, open the source (WAV or otherwise) in Octave/MATLAB/Python/etc. as an array, then use the dft function.
Seven Transistor Labs, LLC
Offline dom0
Re: FFT Software
« Reply #7 on: May 10, 2015, 09:38:07 am »
For basic analysis audacity is ok. It handles unreasonably high sample rats and float audio w/o complaining.
