Author Topic: Homebrew Lock-In Amplifier  (Read 19747 times)
Offline PicuinoTopic starter
    • Picuino website
« Last Edit: May 21, 2024, 05:27:11 pm by Picuino »
Offline zrq
Re: Homebrew Lock-In Amplifier
« Reply #176 on: May 21, 2024, 06:33:13 pm »
I just did some very quick and dirty tests using labview and my 3rd gen Focusrite 2x2 sound card to work as a lock-in ampliifer, apparently one can easily get >110 dB dynamic range at 311Hz and 1112 Hz carrier frequency for 1 Hz IF bandwidth, characterized by comparing the demodulated signal strength when (Line) input is open and when the loopback signal reaches full scale. And it appears to be limited by the crosstalk from the internal generator (using the headphone output), particularly at higher carrier frequencies, so by doing a simple "zeroing" it can be even better.
