The issue with applying a resistor directly from the 29302 output to the load is than now the load current must not go under the minimum load current for the 29302 or the 29302 loses ability to control the output voltage. According to the data sheet this minimum current is 7ma.
Whether this minimum load current is a concern or not, depends. I would not want to use an unloaded supply where the output drifts up and is uncontrolled, thus charging the regulator output capacitors to the maximum supply input voltage. Once the load is connected it sees this higher than regulated voltage from the output caps until they discharge to the proper regulated level. Same situation for a load that is remotely controlled, the voltage would drift up and subject the load to a higher than regulated voltage until the load is enable. Either case could damage load circuits from over voltage.
Since adding an additional resistor is in question I would recommend adding this resistor directly from ground to the 29302 output to sink the minimum current at minimum expected output voltage and avoid any potential higher than expected voltage conditions at the overall regulator output, loaded or unloaded.
Best,
