Author Topic: Negative to Positive DC Voltage Convertor  (Read 1528 times)
Offline basit701Topic starter
« on: May 24, 2015, 05:59:14 pm »
Hello Guys!
After sorting out the transformer configuration problem for my dual voltage supply, another problem exists now. The digital voltmeter i am using has three wires:
1) +12Volt (to turn on the voltmeter)
2) Ground
3) Voltage Measuring
The voltage is measured with respect to ground wire.
However if i connect the voltmeter supply terminal to +12 V and ground and then measure - voltage it does not measure the voltage. The output voltage shown is zero. I was thinking to use op amp 741 inverting configuration with gain of -1 to convert the -ve voltage to +ve voltage but the op amp VCC and VEE limit is 20 volt and my output voltage is 20+.
Any suggestions to resolve this issue?
Offline Waff0l
Re: Negative to Positive DC Voltage Convertor
« Reply #1 on: May 24, 2015, 06:23:03 pm »
I say, take a different opamp which can operate at higher supply voltages like a LM2904
-edit - which is still too small  :palm:, also, does your DVM measure above +12V (its supply voltage)?
« Last Edit: May 24, 2015, 06:27:55 pm by Waff0l »
Offline Zero999
  • 0999
« Reply #2 on: May 24, 2015, 06:27:42 pm »
The LM2904 has a maximum total supply voltage of 36V which is no better than the uA741. In fact the uA741 (not the C version) has a maximum total supply voltage of 44V.
