Seems i can't make a welder of any type that doesn't just immediately vaporize itself.
Long story short: i got some 18650 cells from my internship and i want to make a pack but i don't have a welder. So i made one and it exploded over and over again.
Long story long:
Ok, so the first few failures were my fault because i was basically using whatever scrap MOSFETs i could salvage and was just trying my luck basically.
But recently i was ordering parts from mouser and decided to throw in some proper high current MOSFETs and got 10 MDT4003SCT's.
Made my MOSFET assembly with plenty of copper and added a 10 ohm resistor in series with each gate, more to protect my gate driver than anything really.
Below included is a rough schematic for ease of understanding.
And all was well until today. Previously i used an old battery from my car but it would discharge too quickly, just not enough juice left in it.
So i took my 95Ah 850CCA 12V battery that had a shorted cell and cut that cell open to add a copper bar across the electrodes to bypass it so it's a 10V battery now.
And it took only about three tries before my MOSFET assembly let out the smoke. But while it worked anything i tried to weld would turn into vapor, the peak current was massive.
I actually didn't expect the battery to have this much oomph, like yeah, i know it's new, but it caught me completely offguard just how violent it is.
I'm using a rather short 16mm
2 welding wire to tie everything together, which funnily enough was the thinnest welding wire i could find at the time.
I still have 9 IRF1324PbF's that i got from aliexpress. Had 10 but decided to crack one open to see it it's genuine and it was
Well at least the silion die inside was massive and the bondwires were chunky as well, i'll include a pic.
According to the datasheet IRF1324 has about half the R
DSON of the MDT4003 so i have high hopes for it.
So i still want to make a welder but i think it would be best to put some more effort forth before i blow it up again.
Some thoughts in hindsight:
1. This welder is kind of sort of a boost converter if you squint hard enough so there will be a high voltage spike once my MOSFET's turn off. I knew this already before but wishful thinking lead me to not use a snubber of any kind = big mistake. Now i'm thinking about using a MOSFET as a voltage clamp. I've been experimenting in LTspice already with some source follower MOSFET voltage clamps. I chose MOSFETs because BJTs seem to not handle that well with high peak current. Also i doubt that a zener or a transorb will do. The IRF1324 has a 24V
DSS so i need the snubber/clamp to be fast and reliable.
2. Were my wires too thick?
Perhaps i should have used thinner wire to limit the current. Almost every DIY battery tab spot welder out there uses 6mm
2 wire, which is much thinner than what i use. I kind of went with the idea that more copper = more better but how good is too good?
3. Is my gate driver not good enough? I tried to make it reasonably beefy and used transistors that are capable of 3A sustained current. Or perhaps is the slope too steep and is causing ringing or other unvanted behaviour? I've seen some DIY welder projects where MOSFETs were driven straight from an arduino pin and they worked fine. Surely my driver is not worse than that.
I haven't spent that much money on this project (yet
) but i'm already feeling like i should calm down before i bury myself in a pile of blown up MOSFETs.
Also i took some cool looking macro shots of the blown up MDT4003 MOSFETs. Notice how small the silicon die is, also are those bondwires aluminum or silver?
BTW does Dave still do the magic smoke pic thingy? I have plenty of those
What do you guys think? I guess it's time to place bets whether it explodes again or not.
Pic list:
1. MDT4003 die shot from the side
2. MDT4003 die shot from above
3. MDT4003 blown right out
4. IRF1324 from aliexpress cracked open
5. Gate driver schematic, output stage x10 MOSFETs
6. Gate drive signal with 10nF load cap. Red trace - arduino pin, yellow trace - gate driver output.
7. MOSFET assembly, 10 MOSFETs in total, 5 per side. Double sided FR4 with copper bus bars soldered on. Under the black tape is a strip of protoboard that holds the gate resistors.
