Author Topic: Hot swap controller audible noise  (Read 2510 times)
Offline caffeinatedbardTopic starter
« on: December 05, 2013, 04:09:43 pm »
Hi ,
I have a simple hotswap controller circuit with a high side fet and a common mode choke in series with the load and a 100uF capacitor in parallel with the load.
During testing, trying to test overcurrent with the circuit on sometimes I hear an audible buzzing sound when I short the + and - terminal.  Do you think that would be coming from the FET or from the common choke?
Any suggestions are appreciated.
-bard
Offline ConKbot
Re: Hot swap controller audible noise
« Reply #1 on: December 05, 2013, 04:26:27 pm »
What is the hot-swap controller?  If It might be retrying every few (hundred?) ms, making a nice pulsed waveform.  I'd expect the noise to be coming from the choke, and not the fet.
Online nctnico
« Reply #2 on: December 05, 2013, 06:03:07 pm »
FETs (and transistors in general) can make noise.
Offline envisionelec
« Reply #3 on: December 05, 2013, 07:26:22 pm »
Really? Wouldn't they disintegrate quickly? I've only known chokes and capacitors to make noise...
« Reply #4 on: December 05, 2013, 10:04:25 pm »
The hot swap controller is the LTC4215.
Offline Phaedrus
« Reply #5 on: December 06, 2013, 12:30:19 am »
Put a dab of epoxy on your choke, if it isn't enclosed. That will dampen the vibration.
"More quotes have been misattributed to Albert Einstein than to any other famous person."
- Albert Einstein
Online nctnico
« Reply #6 on: December 06, 2013, 01:16:25 am »
Just run enough current through them. Its not harmful BTW.
