Author Topic: Need help finding a bearing for a motor! HP 113BR frequency divider and clock  (Read 1792 times)
Offline 5065AGuruTopic starter
I'm repairing an HP 113BR clock. It's a 1961 vintage mechanical clock driven by a motor whose speed is controlled by a 100Khz frequency standard input to the unit. The rear bearing on the motor is shot and the manual does not break down the motor that far. :(
I'd like to replace both the front and rear bearings but so far I can't find a substitute. Without my micrometer handy it looks like the shaft diameter is 1/4", the bearing O.D. is 15/16", and the thickness is close to 7/32". I can mike it tomorrow to verify but that is very close. Can anyone help me source this item?
Any help will be appreciated!  :-+
Cheers,
Corby
Online edpalmer42
The two good sources of bearings that I know of are:
https://www.mcmaster.com/bearings/ball-bearings/
https://www.wmberg.com/products/bearings/bearings
But I don't see anything close to your measurements.  Get out your magnifying glass and look at the bearing really closely.  I have bearings that are smaller than yours and they're marked with a part number.  Do you have a manual for the 113BR?  They usually give a part number and manufacturer in the parts list.
Edit:
Out of curiosity I checked to see if I could find any info on the small bearings that I've got.  Add another company to the list:
https://www.nhbb.com/products/miniature-instrument-ball-bearings
« Last Edit: July 06, 2021, 03:56:41 am by edpalmer42 »
Ed,
The manual gives bearing numbers for several other bearings but not the 2 motor bearings.
Also the bearings have no visible markings.
I'll doublecheck tomorrow when I mike the bearing.
Thanks!
Cheers,
Corby
Online mzzj
ID/OD ratio doesn't sound like any standard bearing and very few bearings come with 15/16" OD
Many US manufacturers have used metric ball bearing sizes for historic reasons.
Metric 636 bearing would be ballpark similar size but if you already measured your bearings with anything better than ruler its unlikely to match.
Online jpanhalt
Is it a ball bearing or plain sleeve, like oilite?
If the latter, you may find a proper fit, but usually I just buy something close and turn or ream it to fit.  If you can get the proper ID, turning the OD and adjusting the length is a little easier.
Here is a PIX.
ID .25"
OD .942"
thickness .188"
Extended thickness .218"
Cheers,
Corby
Online jpanhalt
Just looking at that shield, I suspect the balls do not go from the OD of the inner race to the ID of the outer shell.  It looks to me as if it is a relatively standar bearing for a 0.25" shaft pressed into something ( e.g., a donut) with the proper OD and ID corresponding to the OD of the bearing would work.
Offline mikerj
It's something like a R188ZZ in a spacer/bushing to extend the OD.  You need to see if you can extract the bearing to be able to reuse the outer part, if not seems like a relatively simple part to get machined.
Offline Gyro
If the bearing does have a separate outer race, then it must be very thin - all I can see is the circlip that holds the dust shield, it's normally possible to see the outer race around that. If so, it's pretty unusual.
As mikerj says, It should be pretty easy to machine a couple or rings to allow normal bearings to be used.
Best Regards, Chris
Online edpalmer42
How fast does the motor spin?  Does the bearing have to be anything special or would a generic ball bearing do the job?
The motor spins at 1000 RPM and the motor is mounted horizontally. The shaft that the motor drives spins easily and does not require a large torque.
I'll see if I can get the old bearing apart so as to use the outer race as a mount for a smaller diameter bearing.
Cheers,
Corby
Offline BrianInTexas
  • Certified Technogeek
The picture looks to me that the circlip holds the entire bearing within the bushing.
If so, the bearing is not likely press fitted, and it will be possible to measure the OD directly.
If the shaft is 0.25, the OD is likely 0.375.
Took the clips off and the two shields.
Can see the ball bearings now!
Flushed it out with WD40 and it spins nicely now.
I'm thinking I'll re-grease it, reassemble and try it out.
If that does not work I'll regroup!
Any idea what kind of grease to use?
I'd like to use something I could find at NAPA auto, in a small tube maybe?
Cheers,
Corby
Offline BurningTantalum
jpanhalt - I was told, by a mechanical engineer many years ago, that it was not recommended to ream an oilite-type bush. They are sintered and reaming tends to close the 'gaps' - in effect 'smearing' the material and creating a tube that is not lubricated. I seem to remember that it was not recommended to lubricate the bushes either, but I have totally ignored that during my working and hobby life!
BT
Offline james_s
I'm guessing the bearings are probably fine. I'd probably try something like WD-40 to flush out the old grease and then if they spin nicely put a few drops of light machine oil in there, the stuff sold as electric motor oil or sewing machine oil ought to work. If you do need to replace the bearings pretty much any machine shop ought to be able to make you a set of spacers you can press standard bearings into.
Online jpanhalt
BT
Correct.  I should have said better instead of easier.  (In reality, I can't remember a time when I couldn't find the proper ID.)  Oilite are supposedly pre oiled, but some sintered bronze used to come with a need to soak.  In either case, like you, I oil both.
Here are PIX of the "guts".
If the re-lube does not work I'll pull the guts and use a different OD bearing as suggested.
The rear bearing has lots of room to kludge a different bearing.
Cheers,
Corby
Offline BrokenYugo
With such a small bearing I hesitate to suggest ordinary #2 GC-LB chassis/wheel bearing grease. Something thinner is probably (#0 I'd guess) more appropriate, but difficult to aquire in small quantities.
Offline james_s
Most small bearings use oil, not grease. Sewing machine oil or 3-in-1 ought to be fine. It's not rocket science, this is a 1,000 RPM motor, not turbomachinery.
Online edpalmer42
Corby,
Is this the unit that normally runs so noisy that it practically drives you out of the room?
You know you have to post a video of it working, right?   ;)
Ed, It was SUPER noisy with the bad bearing!  :o
Once the motor was removed the input shaft of the clock moves smoothly and quietly so hopeful that it will quiet down a lot! I'll see about a video.
Well cleaning and repacking the bearing did not work!
The bearing is worn inside and allows the shaft to have several degrees of movement!
This causes the rotor to rub.
The front bearing is an order of magnitude better.
I've ordered an R188-2Z bearing and I think I can make it work.
Probably be a week or so before I have any further info.
Cheers,
Corby
