Vias are fine, just match the length (if your EDA tool doesn't calculate routed length correctly, remember to add a board thickness to the route length for every via). Not even a huge deal, it's fast but not bleeding edge fast. (USB standard is free and open -- length and impedance matching specs are in there, take a look.
If you can escape the connector differently, that's another opportunity to swap as well. The one trace will dogleg around taking up much more length which should be balanced with an accordion or whatever on the other line, so remember to allow some space for that.
Also a good idea to keep the overall routed length short, so you don't need to worry so much about impedance matching.
BTW, lengths should be matched over any discontinuity, say if you're routing between VCC domains and the pair happens to be over said power planes. (A typical 4-layer stackup being signal, GND, VCC, signal, so that would be bottom side routing, and the discontinuity being split planes on VCC.) Anywhere up to the discontinuity, it doesn't really matter where the length tuning (accordions or whatever) goes, near the connector, near the edge, in the middle of the route, whatever.
This applies to vias as well, and yes, preferably you'd have them complementary (at matched routing lengths, and in as nearly the same location as possible).
Neither of these really matter all that much in practice, with proper design and routing. Entire planes should not be noisy enough (say 10s of mV, at high frequencies say >100MHz) to pick up significant induction, whether from swapping layers (VCC-GND noise) or by crossing planes (VCC1-VCC2 noise). Placing a bypass cap (VCC-GND) near the via(s) can help.
This is, however, good reason to avoid local current loops in switching supplies, especially fast, high power ones.
Most likely you're routing over one solid plane and neither of these even apply, just FYI to get a feel for the motivation behind it.
Note that you'll basically never meet the impedance spec on a 2-layer board, so I'm just assuming you're doing 4. If not, well, the impedances won't be great, putting even more priority on keeping the route short!
