I am working with a HX711 board. They are used with load cells and weight sensors. You can find them in many Arduino projects and they are probably sold by the thousands.
-work-without-a-ground-pin-connected/?action=dlattach;attach=455386;image)
This is the schematic. It's copied all over the internet.
-work-without-a-ground-pin-connected/?action=dlattach;attach=455392;image)
By comparing the board, the schematic and the HX711 datasheet I found several issues, marked in the schematic.
I's #4 that has me confused.
The HX711 chip has three power pins (VSUP, DVDD and AVDD), but only one ground pin (AGND).
The AGND pin should be connected to the supply ground but it isn't.
Power is supplied to JC9.
VCC (JC9, pin 1) is connected according to the datasheet.
Ground (GND - JC9, pin 4) goes to RATE (input pin, configures the chip for 10 samples/sec) and X1 (crystal pin, configures the chip for using the internal oscillator). It does not go to AGND.
The datasheet confirms that the power ground should go to AGND. No surprise there.
I checked five different boards from two suppliers (at least two different batches) and indeed AGND is not connected to GND.
Yet, the boards work well.
What am I missing?
Thanks,
Tonn
