Hey folks,
Thank you for your help in advance! After searching this forum I couldn't find an answer to my question. so here go's my first post.
Objective: Make a feather duster which is changed with ions to attract dust and then switch the charge so dust is repelled from it when it's time to clean.
I saw this great video on turning a USB air purifier into a static generator.
https://www.youtube.com/watch?v=P5za9sa4-qk
My question is can this project be modified so it can both generate a charge as well as reverse the static charge and repel the dust?
If so, how?
My hope is that if I can do this in a small form factor I can add it to the dusters my cleaning company uses to make us more efficient as we work.
Thank you again!
