Author Topic: Newbie's bench power supply design: build on top of existing units?  (Read 1731 times)
Offline technixTopic starter
  • Country: cn
  • From Shanghai With Love
    • My Untitled Blog
The M103v2 and M103v3 boards were both busts.  :'( Back to the drawing boards.
I have an old Dell laptop power supply with a busted ID chip: it works properly otherwise, but the laptop won't properly recognize it any more. It outputs 65W maximum at 19.5V. Since my output power cap is 50W anyway, maybe I can build my bench power supply from this? Maybe I should use a modular design with hot plugging in mind.
On the same note, another piece of equipment I may reuse is an old ATX computer power supply. What is the best way to repurpose it into a bench power supply with adjustable output voltages? And how to disable the minimum load requirement of the power supply, preferably without using a power resistor and burn away a few watts at all times? Is it a good idea to build the ATX-based adjustable power supply in some kind of standard form factor (like mini-ITX, 170mm-by-170mm board with four screw holes at specific locations) and put the build into a standard small form-factor computer case?
Offline Mechatrommer
  • Country: my
  • reassessing directives...
Re: Newbie's bench power supply design: build on top of existing units?
« Reply #1 on: August 10, 2016, 09:22:29 pm »
put adjustable LM317 on the ATX PSU output
minimum load means energy you should waste for better regulation. use constant current circuit...
  • Country: cn
    • My Untitled Blog
« Reply #2 on: August 11, 2016, 02:53:50 am »
put adjustable LM317 on the ATX PSU output[//quote]
Not acceptable. Should the ATX power supply being used I will shoot for as high the maximum output power as possible, so a switcher is a must-go.
This is no better than a power resistor.
Offline David Hess
  • DavidH
« Reply #3 on: August 13, 2016, 01:53:48 am »
If you use a 317, then the output divider normally also provides the minimum load current.
