Author Topic: power dissipation vs duty cycle.  (Read 471 times)
Offline KokoriantzTopic starter
  • Country: vn
« on: March 09, 2023, 04:15:37 am »
If I apply a 50% duty cycle V volts on R, is the dissipation (V/2)²/R as the average voltage is half or V²/(2*R) as the power is averaged to half?
Offline bdunham7
Re: power dissipation vs duty cycle.
« Reply #1 on: March 09, 2023, 04:59:02 am »
The latter.  Instantaneous power is I2R or V2/R.  You can average the power to get the...well, average power.  If you want to figure the power as a simple function of V and R, you need Vrms not Vavg.  For a 50% duty cycle with a top voltage of V and a bottom of 0, Vrms equals (sqrt(V2/2) (literally the root of the mean of the square).  Apply your power formula to that and R and it should all fall into place.
The following users thanked this post: Kokoriantz
