Author Topic: Battery charge controller and DC-DC in one package  (Read 2026 times)
Offline BoomerangTopic starter
« on: March 07, 2017, 01:11:56 pm »
Is there one IC to solve the two problems: Lithium ion cell babysitting and generating from it stable DC power output?
What I need is really small output power ( < 0.5 W ) and charging from standard 5V USB connector.
Offline cyberfish
Re: Battery charge controller and DC-DC in one package
« Reply #1 on: March 07, 2017, 01:18:44 pm »
What do you mean by babysitting? If you just mean charge and terminate charging correctly, there are many options. Eg. MCP73831
If you need things like over-current and over-temp protection, maybe even coulomb counting, you'll have to look for a battery management chip - http://www.ti.com/lsds/ti/power-management/battery-management-products-overview.page
Those are a lot more complicated.
« Reply #2 on: March 07, 2017, 01:38:19 pm »
Charging (start, stop), overcurrent protection, deep discharge protection and that's all. I don't need coulomb counting, capacity or wear level measurement and etc...
Offline grifftech
    • youtube channel
« Reply #3 on: March 07, 2017, 03:37:18 pm »
buy a cheap power bank and use the board from it.
Offline mvdswaluw
« Reply #4 on: March 07, 2017, 05:02:20 pm »
Not one chip, but have you considered looking at a Adafruit powerboost?
Online Fungus
« Reply #5 on: March 07, 2017, 05:10:14 pm »
You want to manufacture hundreds or do you just need a handful?
If you only need a handful then eBay is full of modules, eg: http://www.ebay.com/itm/122217973743
Offline cyberfish
« Reply #6 on: March 07, 2017, 05:12:26 pm »
I don't think I have seen a chip that does charging and also monitoring. There is always a one-chip solution though - use a microcontroller.
Offline trophosphere
« Reply #7 on: March 08, 2017, 12:33:17 am »
This one from Linear is the only one I was able to find that does charging and has a over discharge disconnect functionality.
In regards to the original poster, the bq2501x Series from TI has lithium ion charging and a built-in DC-DC buck converter. No protection from over discharge built in though.
« Reply #8 on: March 08, 2017, 09:10:39 am »
Thanks a lot! This is exactly what I'm looking for! I spend hours of searching on TI web site and didn't found it...
