Hi
Has anyone built an RGB parallel to MIPI video converter, any recommendation of a chip for this task?
I have in design a video player using a microcontroller. At first I was going to use an H7 from ST, but due to the shortage of components, it is totally sold out, although in the end I got 100 pieces in LQFP208, for certain designs I need BGA for the available space.
So, I'm thinking of using an RT1064 micro that I have in quantity with BGA package and it has parallel RGB video output, but I would need to convert that output to MIPI to be able to use some screens.
I was looking for chips that convert from RGB to MIPI and I only found one from Toshiba in BGA format, with a somewhat fine pitch (0.65), but with few balls and most of them in two rows. I think I could give it a try, unless there is another chip that I don't know about and that is easier to solder (a 0.8mm pitch BGA or an LQFP).
