Author Topic: Recommend me an OCXO.  (Read 22930 times)
Offline VgkidTopic starter
Re: Recommend me an OCXO.
« Reply #25 on: April 07, 2015, 08:45:31 pm »
Ironically that Racal 9500 was the first Frequency counter I was looking at getting. Ordered one on Ebay, and got a message from the seller the next day, saying that his shop was broken into. So no 9500 for me, ended up getting a 5335A.  Now I'm contemplating getting a prologix gpib(used), already downloaded ezgpib/timeLab.
It has begun...
« Reply #26 on: April 22, 2015, 04:55:40 am »
my stp2145A 's came today, along with a neat little gps board.
« Reply #27 on: April 22, 2015, 10:24:26 pm »
The board works, now to wait until summer to start the project.
currently running a non scientific test using the 3456A monitoring the stability of the EFC output voltage.
will update later:
temp span 22.5+/- 1.5C
low = 8.01727   Hi = 8.01734  mean = 8.01730  var = =.170525E-9
count = 6411 measurements, 100nplc, 6 digits
« Last Edit: April 23, 2015, 04:23:52 am by Vgkid »
Offline bingo600
« Reply #28 on: April 24, 2015, 02:21:35 pm »
It has begun...
Poor sod   :palm:
Being bitten by the time bug is EXPENSIVE :scared:
My infection started with "just wanting to cal" my old PM6674 counter.
Ended up with 3 x Tbolts , 5 x Rubidiums
You have been warned  :phew:
/Bingo
And now i've been bitten by the volt bug  :palm:
« Last Edit: April 24, 2015, 08:11:35 pm by bingo600 »
Offline feedback.loop
« Reply #29 on: April 29, 2015, 12:04:37 am »
You may want to check out this video: https://youtu.be/0UT6smae8M0
Two OCXOs are tested there:
1. Morion MV85a 5V sine wave
2. C-MAC 12V square wave
« Reply #30 on: April 29, 2015, 02:40:41 am »
Thanks for the video. If you dont mind me asking, where are you from?
I think i might have most beat on number of ocxo's. 54
« Reply #31 on: April 30, 2015, 05:14:36 am »
Measured the current draw at 21C for the stp2145A
init = 546mA, min = 147mA, avg = 178mA
Offline xrunner
  • hp>Agilent>Keysight>???
« Reply #32 on: April 30, 2015, 01:41:22 pm »
100 MHz OCXO - Valpey Fisher. Form Ebay for $40. Now I have a 10MHz and a 100 MHz. Must obtain more ...
« Reply #33 on: April 30, 2015, 11:11:21 pm »
I almost thought about picking up a 100MHZ ocxo. Currently logging the evc out on one of the 2145A's. Which is being fed by a rather precise(and stable) 10v source(as opposed to 12v). will update later.
Offline Hole
« Reply #34 on: August 02, 2016, 11:07:16 am »
I know its old, but just to add some details.
I got a racal 9500 series counter and here is what I found inside. Name seems to be M95OSEO or M950SE0.
Previouse owner marked "option 22a installed" in the manual, which says "Aging rate: < 3x10^-9/day, Temperatur stability: < 3x10^-97°C 0° C to +50° C, Voltage Stability: <2x10^-8 with 10% line V variation".
It looks like C5 had to suffer some abuse. Not sure what all the stuff does... Currently the counter is very very spot on.
« Reply #35 on: August 02, 2016, 05:40:18 pm »
C5 might be a decoupling capacitor.
Offline Hole
« Reply #36 on: August 02, 2016, 06:09:27 pm »
Yes, all the lighter colored ones seem to be decoupling. And it totally looks like a later made hack.
Another mystery is channel C. It is available as option 41 (50 to 512 Mhz) and option 42 (50 to 1.25 GHz). I can't find out what is build in, I don't see any markers etc.
Perhaps I should draw a schematic...
[times passes...]
ocxo is a Frequency Std. 9442/5, 5 MHz fast warm up. And I assume that the pcb is some frequency doubler (OR + RC).
« Last Edit: August 02, 2016, 11:32:42 pm by Hole »
