Hi All,
Been working on this for the last 4 weeks and got no where
I am attempting to build a Timed Relay cut off.
So story behind this.
My work van has a continuous 12V power though its cigarette jacks
not good if you forget to unplug something and kill the battery (already done twice)
so what i want to do is build a Circuit that switches off after 15mins of the car been off
Now i have a trigger in place for this so need this circuit to start a time once the trigger is lost
and if i turn back on in within the 15 min the timer holds until loss of trigger again and restarts the 15 minutes again
now i have got a nice cheap circuit from china that does the job but one big issue
The trigger is a once off so once triggered the circuit starts the timer no matter if the trigger is always there it times and shuts off grrr
so every time the circuit turns off i have to restart the trigger
find circuit below
https://www.ebay.com.au/itm/DC-12V-30A-1S-1H-Trigger-Delay-Turn-On-Off-Timer-Control-Relay-Switch-Module/192178341085?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649now i have attempted to program up an Arduino with not much luck have kinda got it working then does not work so i am running out of ideas
Any help would be nice
Thanks
Anthony
