Electronics => Projects, Designs, and Technical Stuff => Topic started by: ali_asadzadeh on June 13, 2017, 10:37:18 am
Title: How does this sealing machine works?
Post by: ali_asadzadeh on June 13, 2017, 10:37:18 am
My friend send me this puppy for repair, I just wanted to know what's the principle behind it, I can see it has a full-bridge MOSFET that is tied to a mysterious big chunky inductor that's connected to this huge heat sink. which I think can do the welding with the magnetic field.
any Ideas are welcome!
Title: Re: How does this sealing machine works?
Post by: ali_asadzadeh on June 13, 2017, 11:02:04 am
The main controller part is SG3526 and the MOSFETs are APT55M50JFLL  ,and two  IR2113 MOSFET  drivers, you can see the big self and caps there, I think they have used the litz wire for them!  there is nothing special with this puppy, everything is jelly bean parts.
Post by: P90 on June 13, 2017, 11:06:38 am
looks like it's an inductive sealing unit. An inductive coil creating a varying magnetic field heats some sort of aluminium layer in the sealing material and melts it to the container.
Post by: ali_asadzadeh on June 13, 2017, 11:57:37 am
Thanks for the info, would you explain more? how is the SG3526  working? do you have any tutorial or app note about it
Post by: macona on June 14, 2017, 05:31:43 am
Yep, its an inductive sealing unit, it heats up the metal foil in the package which melts the plastic when it is squished in the sealing jaws.
The SG3526 is a pretty generic PWM chip, it drives the gates of the mosfets in a H-bridge which turns the DC coming in to AC, basically a high frequency inverter. The rectangular blue caps are part of the tank circuit.
Post by: ali_asadzadeh on June 14, 2017, 12:03:46 pm
Thanks Macona, Do you have a simplified circuit diagram? thanks in advance
