Author Topic: Implement Battery charging algorithm along with MPPT algorithm to charge battery  (Read 475 times)
Offline SiddhatTopic starter
  • Country: np
Hey, hope everyone is doing fine!
I need to charge a lead-acid battery from a solar panel. In order to extract the maximum power from the solar panel, I have already implemented the MPPT algorithm (written the code)  in a buck-boost converter and simulated the circuit and the algorithm in MATLAB. Attached below is the schematic.
But, I want to charge a lead-acid battery at the output of the buck-boost converter. I know that I have to implement a battery charging algorithm that has 3 or 4 stages. But I am unable to do so.
The problem that could not figure out is how do I implement the battery charging algorithm along with the MPPT algorithm with a single stage of a buck-boost converter??
