Author Topic: uSD too bulky, what other storage is there?  (Read 1590 times)
Offline cdwijsTopic starter
« on: April 09, 2016, 04:13:34 pm »
Hi All,
I would like to build a very small datalogger. So small in fact, that I'm looking for something that can hold some (megabytes of) data, but is smaller than an uSD card.
I have found a chip that's 5x6mm, but I would like to know what other options are out there:
http://nl.farnell.com/spansion/s25fl164k0xnfi011/ic-memory-flash-64mbit-wson-8/dp/2363324
Kind regards,
Cedric
Offline exmadscientist
  • Technically A Professional
Re: uSD too bulky, what other storage is there?
« Reply #1 on: April 09, 2016, 05:07:55 pm »
What are your requirements (both minimum and goal)? Size and preferred interface are both important.
There are plenty of truly tiny memories out there, some even below 1 mm². But the really small ones can't store much: there's both a die size limitation and a minimum pin count for the interfaces on the larger (parallel) memories.
The 5 mm×6 mm size serial flashes are quite common, with options from many manufacturers. There are also several available in 2 mm×3 mm, but the selection there does decrease.
Offline ajb
« Reply #2 on: April 09, 2016, 05:54:11 pm »
Note that with the larger serial memories, the minimum erasable size may get to be a bit large (4kbyte in the one you linked), so if you want to do a circular log (write until full, then start overwriting the oldest data) you will need to either give up an entire sector of data at a time or be able to hold a 4kB (or whatever) buffer in your MCU's memory before writing to the external memory.
