Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
How generate a pdf file for bottom layer in eagle CAD?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: How generate a pdf file for bottom layer in eagle CAD? (Read 829 times)
Dhanushka
Regular Contributor
Country:
on:
June 24, 2019, 05:39:57 pm »
I have downloaded the attached Eagle files from internet and it is a variable power supply.
I am very new to Eagle.
So, Please anyone tell me how generate separate pdf files for bottom layer and top silk layer.
It is better for me to upload the separate files.
Thanks
Last Edit: June 24, 2019, 05:43:03 pm by Dhanushka
Logged
rstofer
Super Contributor
Country:
Re: How generate a pdf file for bottom layer in eagle CAD?
Reply #1 on:
June 24, 2019, 05:49:43 pm »
I don't use Eagle so ignore everything that follows...
Can't you PRINT a layer to a Color LaserJet or <whatever> If so, why can't you print to the Microsoft PDF Printer device? It's standard on Win 7 and Win 10.
I have no idea how sheet size will work out.
Logged
Dhanushka
oPossum
Super Contributor
Country:
Very dangerous - may attack at any time
Reply #2 on:
June 24, 2019, 05:55:43 pm »
View menu, Layer settings...
File menu, Print, Print to PDF
Logged
Dhanushka
Dhanushka
Regular Contributor
Country:
Reply #3 on:
June 24, 2019, 05:59:43 pm »
Dear rstofer and oPossum,
Actually the problem is when I open this file on eagle, it will show every layers. So, I need to generate pdf files separately to print. Example: bottom layer
Thanks
Last Edit: June 24, 2019, 06:01:39 pm by Dhanushka
Logged
Karel
Super Contributor
Country:
Reply #4 on:
June 24, 2019, 06:43:06 pm »
Menu -> View -> Layer settings. Switch on/off the layers as you wish. Hit the Apply button. Check the result. Close the Layer settings.
Hit ctrl+p. The printdialog will appear. Instead of a printer, select PDF. Adjust the filename and path.
Adjust other settings as you whish.
Hit the OK button.
Logged
Dhanushka
Dhanushka
Regular Contributor
Country:
Reply #5 on:
June 25, 2019, 02:40:44 am »
Dear Karel,
It worked
Thank you very much.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
