UL508's limited energy circuit definition comes to mind (5A at up to 20V, 100VA up to 42.4V; that's VDC or Vpk and A RMS), though that's industrial and I'm not sure offhand which standards (and sections thereof) should apply to commercial/office/telecom equipment. I don't recall reading anything about amperage in IEC 60950-1 but I may be forgetting something, and also 62368-1 is the newer version more or less so may have other changes. Which coincidentally, the linked power supply has all the stamps from these (plus '601), so that would be good further reading if you need to be sure.
Agreed, good idea to plan for incorrect supplies; label appropriately (legal CYA), putting in a fuse is probably a good idea.
Note that SMT chip fuses -- fuse-fuses, not PTCs -- are cheap and plentiful. This power level is kind of near the upper limit where PTCs are reasonable, so availability or cost might be poorer, and functionality worse (slower from the bigger thermal mass?), but they're also definitely doable. Well, I haven't checked stock on 'em lately, but y'know... in ordinary times they'd be available, at least.
Probably plan for excess and reverse voltage, too -- maybe a crowbar diode or something. For OV, might be good enough to just let a SMAJ size TVS cook off, fail shorted (potentially) and clear the fuse (or shut down the supply) that way?
What are better/alternatives to the fuse?
PPTC
Circuit breaker
Current limiting design (limits maximum current and all components can tolerate short circuit, like a lab PSU)
Foldback current limiting design (reduces current to a low value on overload--LM series)
Current overload reset design (disconnects on overload, needs power cycle to reset--ATX for example)
Impedance protection design (short circuit tolerant--Class 2 transformers, etc.)
You can't protect against absolutely everything, of course; they can always build a better idiot. Say it gets cross-wired to 120, or even 240V mains, right? So it's still a good idea to put in a conventional, reliable method, like a fuse, on top of these methods. So you might combine a current limiter with an overvoltage crowbar, so that it's able to ride through excess voltage (whether fully functional during, or switched off by OVLO), but still confidently clears the fuse when pushed beyond absolute maximum.
And for that matter, mind the fuse ratings; typical SMT chips are like 50 or 100V and a rupture current of say 20-100A, that sort of thing. Obviously not great if mains hit that, so you might want a larger (brick or cartridge) type in that case. But it would be perfectly adequate for most low voltage applications, even against beefy-ass batteries if you have enough internal resistance on your end to guarantee the rupture current is not exceeded. (Which is also a good way to use PTC fuses, have enough resistance to guarantee not exceeding Imax -- and you should get a reasonable number of cycles out of it. Which, keep in mind, cycle life is like, dozens, they aren't terribly reliable parts. Use them as you would any other fuse -- as a last resort!)
So that pretty comprehensively covers everything from the casual (none, or a fuse), to industrial or aerospace grade protection.
