Author Topic: How many uF this axial capacitor?  (Read 3327 times)
Offline sdancer75Topic starter
  • Country: gr
« on: September 25, 2019, 05:55:21 pm »
Maybe it looks stupid but....
Is that white axial capacitor 1uF (2nd photo) ? I am not sure if I can decode the markings of this like 1/10 and 1.70MKP
Also the small smd in the 1st image, just beside the IC is also a capacitor; I get continuity on this part.
« Last Edit: September 25, 2019, 06:38:07 pm by sdancer75 »
Offline GreggD
Re: How many uF this axial capacitor?
« Reply #1 on: September 25, 2019, 06:41:22 pm »
Looks like 1.7uF. It is large enough to be that.
Continuity, Some where else there is a resistor across the cap or some continuity through an IC
The following users thanked this post: sdancer75
Offline amyk
« Reply #2 on: September 26, 2019, 01:44:15 am »
Google it first... https://www.tedss.com/2020043114 suggests you have a 0.1uF 250VAC  metalised polypropylene capacitor.
  • Country: gr
« Reply #3 on: September 26, 2019, 02:50:44 pm »
I measure 300nF and 0.85 ESR
So it seems impossible to have more capacity than originally had. Maybe it's an 1μF instead with 10% tolerance?
« Last Edit: September 26, 2019, 02:59:33 pm by sdancer75 »
Offline frozenfrogz
  • Having fun with Arduino and Raspberry Pi
« Reply #4 on: September 26, 2019, 03:13:17 pm »
1 µF, 10 % tolerance should be correct.
1.70MKP is the part series.
AV marking was from Arcotronics that are now owned by KEMET.
Edit for reference:
0.1 uF 10 % would be marked .1/10
0.33 uF 5 % -> .33/5
etc.
He’s like a trained ape. Without the training.
Offline schmitt trigger
  • Country: mx
« Reply #5 on: September 26, 2019, 03:40:41 pm »
The ceramic cap appears like a decoupling cap across pins 1 and 14, which are commonly used by Microchip as the Vdd and ground.
So if you are measuring "continuity", it means one of two things:
- somewhere across the many loads between +5v and ground there is a low impedance....it is not necessarily this particular capacitor that could be faulty.
- that your meter has a test voltage which could forward bias some semiconductor junctions.
  • Country: gr
« Reply #6 on: December 12, 2019, 08:49:37 am »
Can I replace the original axial film capacitor 1uF/250V/10% with a ceramic 1uF/250V/10%?
This part is from a refrigerator control board.
Regards,
Offline TurboTom
« Reply #7 on: December 12, 2019, 10:18:19 am »
The cap is likely a safety-rated component (X cap) due to the 250V~ spec. Don't replace it with a 250VDC rated part since it will probably fail (possibly in a spectacular manner) instantly or over a short time. Get the proper replacement!
  • Country: gr
« Reply #8 on: December 13, 2019, 09:26:58 am »
The replacement part is Metallized Polypropylene Film and not ceramic as I wrote before sorry. It is not safety-X-rated cap but its also 250V and VDC. So, will this part work?
Online Gyro
« Reply #9 on: December 13, 2019, 09:48:28 am »
No, that is a DC rating and the original is AC rated. The peak voltage of a 250V RMS AC sine wave is nearly 360V. You need to replace with at least 400V DC rating.
« Last Edit: December 13, 2019, 09:50:44 am by Gyro »
Best Regards, Chris
  • Country: gr
« Reply #10 on: December 23, 2019, 08:54:44 am »
Maybe it's sound a stupid question, but how did you understand that Metallized Polypropylene Film capacitor above is DC rating. From the marking, I can only decode the capacity and the voltage rating. It does not say if is AC or DC.
A 400V Metallized Polypropylene Film will be a good replacement part for the original axial metalized polypropylene?
« Last Edit: December 23, 2019, 08:58:15 am by sdancer75 »
Offline mjkuwp
  • mechanical engineering defector
    • The Mz Lab
« Reply #11 on: December 23, 2019, 12:19:40 pm »
The part has "250 V~" printed on it and the assumption is that "~" is a sine wave.  This is what suggests 250 V AC rating.
Online Gyro
« Reply #12 on: December 23, 2019, 01:02:17 pm »
Yes, if not explicitly indicated, assume that it is a DC rating - it is almost universally true.
The 250V~ marking is one of those exceptions, it normally applies to things like induction motor run capacitors, again where it will be very clearly indicated.
Best Regards, Chris
  • Country: gr
« Reply #13 on: December 23, 2019, 01:41:58 pm »
Thank you for your answer but I meant the other part that has no indication at all but it clarified from Gyro !!
Offline gbaddeley
« Reply #14 on: December 25, 2019, 08:02:29 am »
Agree with Gyro. Replacement needs to be 250VAC rated, 1.7uF. Preferably MKP for its self healing properties. A VDC rated cap could be used, but I would go over 400V for extra margin of safety, say 630V. You don’t want it to blow if there is an AC mains surge.
Glenn
  • Country: gr
« Reply #15 on: December 25, 2019, 08:47:21 am »
Thanks
Why are you mention 1.7uF instead of 1uF?
Offline gbaddeley
« Reply #16 on: December 26, 2019, 11:39:21 am »
I stand corrected, 1.70MKP is a series designation. 1/10 indicates 1uF , 10%
Glenn
