Author Topic: How many vias to connect a small ground zone under a small boost converter ?  (Read 1497 times)
Offline microviaTopic starter
About the specifics, you are overthinking all this.  No need for star grounds.  No need to worry about EMI at all.  You are never going to get FCC/CE tested and you won't have the test equipment to measure it, so don't sweat it.  Just select a part that has a recommended layout and copy that.  TI is really good about this (Yes I know everyone rips app notes and recommended layouts and such, but it's a significantly better starting point that this).
No need to worry about EMI with a boost converter IC not far from an RF chip ? I made a special test pcb with four different boost converter ICs, three of which used the same type of inductor and capacitors. Of course I selected a suitable shielded inductor, and capacitors with derating and proper size. Two ICs significantly altered the RF operation of the target circuit. A third one made it work ok but not as good as expected. The last one gave satisfactory results.
Just a side subject question.
I always apply 2 vias directly under the tab of 1206 smd capacitors.
I see this is avoided here, is it a bad idea?
It's not avoided, but as some PCBAs charge more for that, I must consider the best option.
Of course, if I use JLCPCB's free vias-in-pad, I will update the layout accordingly.
Offline Kokoriantz
  • Country: vn
Thanks, luckily, I only deal with JLCPCB.
Here's the updated layout around the boost converter IC with improved ground path.
The real question is whether anything can be improved, especially if I put too many vias. I can add one under the bottom capacitor.
