Ive read about that - my raspberry pi supports it on receive.. The cobalt is very old, its almost 18 years old now.. so its a 250 MHz, (64 bit) machine using a MIPS CPU and two DEC tulip NICs. It has 256 MB RAM. So its less powerful than the RPI and much bigger. I could fit at least four, possibly as many as a half dozen RPIs inside it as its got a lot of empty space. But I would actually like to keep it the way it is, because its a pretty neat machine, despite its age.
The little (Venus
GPS module I am using now supports PPS.. Its very small, the size of my fingernail. Its smaller than the smallest RTLSDR.
# ppstest /dev/pps0
trying PPS source "/dev/pps0"
found PPS source "/dev/pps0"
ok, found 1 source(s), now start fetching data...
source 0 - assert 1500084226.195970675, sequence: 3332 - clear 0.000000000, sequence: 0
source 0 - assert 1500084227.196005675, sequence: 3333 - clear 0.000000000, sequence: 0
source 0 - assert 1500084228.196038675, sequence: 3334 - clear 0.000000000, sequence: 0
source 0 - assert 1500084229.196073675, sequence: 3335 - clear 0.000000000, sequence: 0
source 0 - assert 1500084230.196107675, sequence: 3336 - clear 0.000000000, sequence: 0
source 0 - assert 1500084231.196141675, sequence: 3337 - clear 0.000000000, sequence: 0
source 0 - assert 1500084232.196176675, sequence: 3338 - clear 0.000000000, sequence: 0
source 0 - assert 1500084233.196211675, sequence: 3339 - clear 0.000000000, sequence: 0
source 0 - assert 1500084234.196244675, sequence: 3340 - clear 0.000000000, sequence: 0
source 0 - assert 1500084235.196279675, sequence: 3341 - clear 0.000000000, sequence: 0
source 0 - assert 1500084236.196313675, sequence: 3342 - clear 0.000000000, sequence: 0
source 0 - assert 1500084237.196347675, sequence: 3343 - clear 0.000000000, sequence: 0
source 0 - assert 1500084238.196381675, sequence: 3344 - clear 0.000000000, sequence: 0
source 0 - assert 1500084239.196415675, sequence: 3345 - clear 0.000000000, sequence: 0
source 0 - assert 1500084240.196450675, sequence: 3346 - clear 0.000000000, sequence: 0
source 0 - assert 1500084241.196484675, sequence: 3347 - clear 0.000000000, sequence: 0
source 0 - assert 1500084242.196518675, sequence: 3348 - clear 0.000000000, sequence: 0
source 0 - assert 1500084243.196552675, sequence: 3349 - clear 0.000000000, sequence: 0
source 0 - assert 1500084244.196587675, sequence: 3350 - clear 0.000000000, sequence: 0
source 0 - assert 1500084245.196621675, sequence: 3351 - clear 0.000000000, sequence: 0
source 0 - assert 1500084246.196655675, sequence: 3352 - clear 0.000000000, sequence: 0
source 0 - assert 1500084247.196690675, sequence: 3353 - clear 0.000000000, sequence: 0
source 0 - assert 1500084248.196724675, sequence: 3354 - clear 0.000000000, sequence: 0
source 0 - assert 1500084249.196759675, sequence: 3355 - clear 0.000000000, sequence: 0
source 0 - assert 1500084250.196792675, sequence: 3356 - clear 0.000000000, sequence: 0
source 0 - assert 1500084251.196826675, sequence: 3357 - clear 0.000000000, sequence: 0
source 0 - assert 1500084252.196861675, sequence: 3358 - clear 0.000000000, sequence: 0
source 0 - assert 1500084253.196895675, sequence: 3359 - clear 0.000000000, sequence: 0
I'm still getting the bugs worked out of my pps setup. There would definitely be both the room and power inside the cobalt for a GPSDO.
I wonder how the cobalt compares to this Elan processor.
http://www.febo.com/time-freq/ntp/soekris/index.html
