Author Topic: What low Iq LDO do you use?  (Read 2808 times)
Offline Mad IDTopic starter
« on: September 10, 2015, 12:53:35 pm »
for my battery powered designs I usually use NCP4587 LDO from ON Semiconductor. It's a great LDO because it's quiescent current is only 1uA when the CPU is sleeping but can deliver great transient performance by adjusting it's ground current quickly.
The problem is that it is very small and it's not suitable for some boards (SOT-23 version not easily available).
Can you recommend a LDO which has very little ground current when the output current is low (<100uA) but can provide very good load transient on higher currents. In other words, the LDO should increase it's internal current on higher loads to provide performance and be ready for load steps.
I find it difficult to find a LDO similar to NCP but in bigger package.
Thanks
Offline rvalente
  • Country: br
Re: What low Iq LDO do you use?
« Reply #1 on: September 10, 2015, 01:41:30 pm »
MCP1711 is available in SOT-223 as well, active current of 600nA...
http://ww1.microchip.com/downloads/en/DeviceDoc/20005415A.pdf
MC1700 you can get even in TO-92, SOT-89 and SOT-223 (or even DFN), the acitve current is bigger, 1.6uA.
http://ww1.microchip.com/downloads/en/DeviceDoc/20001826C.pdf
Have you check TI's parts?
Sometimes I find myself in similar situations, I was looking for a boost buck converter, which would take one LiPo and output 3V3, lots and lots of parts available from all vendors, but they're all tiny tiny, probable smartphone market oriented.
« Reply #2 on: September 10, 2015, 03:34:39 pm »
Heh, these regulators are very very slow. If I have any device which can draw 50mA in transient output voltage would drop which can reset the CPU and cause all kind of problems. That's why this is hard :)
I want to avoid using two LDO, one for sleep and other during operation..
Offline rvalente
  • Country: br
« Reply #3 on: September 10, 2015, 03:41:41 pm »
Hum, can't you fit one or two tantalum capacitor?
« Reply #4 on: September 10, 2015, 03:45:51 pm »
In a lot of cases no, that is why I'm searching for a good LDO.
10uF should be enough to provide me with good transient response from 5 -> 50mA.
Offline mikerj
« Reply #5 on: September 10, 2015, 03:50:06 pm »
LP2981-N maybe?
« Reply #6 on: September 10, 2015, 03:52:10 pm »
Offline ralphd
    • Nerd Ralph
« Reply #7 on: September 10, 2015, 07:46:37 pm »
I have recently been looking for something similar.  The xc6206(662k) is one I'm thinking of buying.  Ive seen them even cheaper than the ams1117.
http://www.torex-europe.com/products/range/120
Unthinking respect for authority is the greatest enemy of truth. Einstein
