Author Topic: Bridge Rectifier over-voltage  (Read 1023 times)
Offline ThermallyFrigidTopic starter
« on: October 08, 2022, 02:43:52 am »
G'day mates!
I am wondering if you could tell me why this KBU1010 Bridge Rectifier has an output of 342V DC (in circuit (no load)) with an input of 120v AC ?
The AC measured at the AC legs is exactly 120v AC.  But the DC output is far greater than expected.  In fact, almost exactly double the expected value.
I was expecting 121v * 1.41 = ~ 169.2v DC
Do I need to remove it from the circuit to measure these voltages?
Thanks
« Last Edit: October 08, 2022, 02:52:37 am by ThermallyFrigid »
Offline bdunham7
Re: Bridge Rectifier over-voltage
« Reply #1 on: October 08, 2022, 02:53:07 am »
Does your PSU have a voltage selection switch?
The following users thanked this post: ThermallyFrigid
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: October 08, 2022, 04:13:03 am »
The explanation for the above comment being:
If it's made for 120V use only, it may be hard-wired this way, maybe with a jumper rather than a switch.
Seven Transistor Labs, LLC
« Reply #3 on: October 08, 2022, 12:55:39 pm »
Hello,
This unit only accepts 110v - 120v
Schematic attached below
« Last Edit: October 08, 2022, 01:05:40 pm by ThermallyFrigid »
« Reply #4 on: October 08, 2022, 12:59:49 pm »
Thank you sir.
I'll re-examine the PCB and look for such a jumper or hard wiring.
Offline bdunham7
« Reply #5 on: October 08, 2022, 01:21:32 pm »
Can you zoom out on that schematic?  It might be obvious if we could see the whole thing.
Offline Vovk_Z
  • Country: ua
« Reply #6 on: October 08, 2022, 01:36:10 pm »
It may have an input auto-range technology too.
Offline David Hess
  • DavidH
« Reply #7 on: October 09, 2022, 06:56:05 pm »
It is configured as a voltage double to produce 340 volts DC from 120 volts AC.  This way it can support both 120 volt AC and 240 volt AC inputs by disabling the voltage doubling function.
