Author Topic: DIY Near Infrared Camera Takes Teardown To The Next Level  (Read 10829 times)
Offline Dave
  • Country: si
  • I like to measure things.
Re: DIY Near Infrared Camera Takes Teardown To The Next Level
« Reply #25 on: May 18, 2016, 07:47:03 pm »
The laws apparently differ from country to country. Here in Slovenia you are awarded with the title engineer (actually various flavors of it) by acquiring a college diploma in a field of engineering. I would have imagined the laws were in sync across the european union, but apparently they aren't.
<fellbuendel> it's arduino, you're not supposed to know anything about what you're doing
<fellbuendel> if you knew, you wouldn't be using it
Online janoc
« Reply #26 on: May 19, 2016, 09:54:17 pm »
They aren't, at least not in the names of the uni degrees. The Bologna accords only specify how many years/credits you need to accumulate for which degree, but not what it should be called. That is very much a traditional thing between the schools and the US/UK style of degrees and the more "continental" ones derived from the German/French systems.
