Based on the inputs, it looks like an aluminum heat sink over the CPLD may be the cheapest solution for the problem. They are easy to buy and install..
Not sure of Zinc sheets, will check if they are available online.
One of those tin plated steel EMI cans may be better than an aluminum heat sink depending on the relative thickness. And as that intersil appnote listed above suggests copper ground planes on the PCB side helps a lot.
Basically, x-rays come out of the source in an energy spectrum. X-rays are efficiently stopped by materials that have ionization transitions comparable to the xray energy. The bigger the atomic number, the higher energy the innermost electrons ionization energy and the higher total absorption cross section for lower energy x-rays. You mostly only care about the xrays that will be absorbed by silicon (Z=14) or other elements inside your chip -- higher energy xrays will just go right through with little fuss. Aluminum (Z=13) is only marginally effective at stopping the x-ray energies that you care about. Iron (Z=26), copper (Z=29) and tin (Z=50) are going to be much more effective even if they are substantially thinner.
