Author Topic: Simple MOSFET load switch design  (Read 397 times)
Offline FBMinis
  • Country: pt
« on: April 21, 2021, 09:17:15 pm »
I would like your help designing a circuit that would use a PIR sensor to turn ON an ESP32 CAM.
The PIRoutputs 3.3V when it detects motion and remains HIGH for up to 5min ( 1sec min, user defined). This signal would pull the P-Channel Mosfet LOW, powering the ESP32 CAM, which would send me a notification to Telegram with the option to take a photo. I would then either turn the camera off by pulling the N-Mosfet gate LOW again (assuming no motion detected by the PIR), or I could just set the output of the PIR to remain high for only couple of minutes to give the camera time to send a notification and expect for my instruction to take a photo or not.
I read this document: https://www.onsemi.com/pub/Collateral/AND9093-D.PDF
Not sure if I got it right and which resistor values to use. The camera momentarily pulls up to 300mA when doing WIFI operations.
Please take a look at the circuit diagram in attachment.
Online ledtester
Re: Simple MOSFET load switch design
« Reply #1 on: April 21, 2021, 11:53:42 pm »
This signal would pull the P-Channel Mosfet LOW, powering the ESP32 CAM ...
Just connect the PIR to a GPIO pin and put the ESP32CAM in sleep mode waking up when the GPIO pin changes.
Have a look at this project:
https://randomnerdtutorials.com/esp32-cam-pir-motion-detector-photo-capture/
Offline FBMinis
  • Country: pt
« Reply #2 on: April 22, 2021, 10:01:07 am »
The ESP32 CAM consumes 6mAh during deep sleep, which isn't adequate to a battery powered project.
« Last Edit: April 22, 2021, 10:03:01 am by FBMinis »
Online ledtester
« Reply #3 on: April 22, 2021, 03:23:17 pm »
Ok, I see.
Here is some more info I found related to the "deep-sleep strategy":
This article investigates the source(s) of this current consumption:
https://time4ee.com/articles.php?article_id=126
It suggests performing some surgery on the board which allows the existing P-MOSFET to control power to the SD card and camera.
And this github discussion shows how someone did this for the camera power:
https://github.com/espressif/esp32-camera/issues/247#issuecomment-801109299
Offline FBMinis
  • Country: pt
« Reply #4 on: April 22, 2021, 10:02:58 pm »
I am aware of that, thank you. However, my project does not rely on deep sleep.
I'd still appreciate some criticism regarding the circuit in my first post.
