I'm planning to run an M470-50A UT13x17 54mm length core at 1.6Tesla, at which point it's well saturated. (stacking factor of around 4.1)
But at what tesla value can I expect the core to still excite the secondaries?
I have around 19.8VA draw from the secondaries. 1.7VA loss @ 1.6Tesla for the core. (0.385kg)
I'm expecting 0.22V/turn for the secondary voltages to be right. and my primary is 1000 turns, 80 ohms and powered with 237V 50Hz.
@ ~22VA the primary voltage would then drop to around 229V.
But how many turns/volt will I still have because of how low the permiability is at 1.6Tesla?
Here's the values for the core steel:
@ 50 Hz
J[mT] H[A/m] Ps[W/kg] μr[-] 1100 135 2.04 6502 1150 142 2.21 6423 1200 152 2.40 6285 1250 164 2.60 6059 1300 184 2.81 5625 1350 217 3.04 4941 1400 273 3.31 4080 1450 378 3.61 3049 1500 634 3.93 1882 1550 1155 4.21 1068 1600 2045 4.47 622 |
