Hi there,
I've designed a LED board with multiple colors (true green, deep blue, white 5000k, etc) and am using individual LED drivers for each color. The LEDs are "sprinkled" around the PCB, which uses aluminum as the dielectric for better dissipation. I'm using DALI to control the dimming of the various drivers, but some of them, when turned OFF, leave some of the LEDs glowing. Only after removing the phase connection the leds stop glowing. Either that or disconnecting both outputs (LED+ and LED-). Leaving the phase connected with the neutral disconnected, the LEDs keep glowing, leaving both the phase and neutral connected and just disconnecting LED+ leaves the LEDs glowing too. I don't think it's a case of a faulty LED driver since I've switched the drivers between themselves and the problem keeps happening. The heatsink where the PCBs are screwed down to is connected to Earth, but I have also tried disconnecting the earth wire and nothing changed. I am going to try and add some capacitors to the input, but don't think it's going to help much.
Any ideas?
