Author Topic: How to control DC 30 amps and pneumatic central lock valve  (Read 563 times)
Offline tlhsglmTopic starter
« on: December 27, 2019, 06:16:06 am »
Hi fellows,
1- I have to control(just on/off) a mini compressor, 12v 21 amperes.What is the fastest way to do this?
2- I will use a valve that drives 2 cylinders.That valve has a specialy, it have central locking, when i lift the load with cylinders, i will lock the valve to prevent load go down.This is important, i dont want compressor to work always.when i want the load to go down, i will simply make valve to stop locking.Is anybody work with this valves?How can i do that?Valve is 12v 4W.
« Last Edit: December 27, 2019, 06:28:48 am by tlhsglm »
Offline Kalin
Re: How to control DC 30 amps and pneumatic central lock valve
« Reply #1 on: December 27, 2019, 04:31:03 pm »
Some more information will be needed about the valve and what exactly you are looking for to control it, but for 12V 30A I would either use a Solid State Relay or a contactor. What are you using for process control, ie: do you have a PLC or are you planning to use an arduino or is this entirely discrete controls(pushbuttons and limit switches)?
The following users thanked this post: tlhsglm
Offline i_am_fubar
« Reply #2 on: December 27, 2019, 05:14:47 pm »
30A 12v is well within MOSFET territory if you want solid state. But SS relay is also option
