Author Topic: How to create a capacitive touch pad in Kicad?  (Read 3488 times)
Offline redgearTopic starter
« on: August 30, 2020, 03:11:17 pm »
I am trying to create a touch pad for use with the CAP1203 IC. How do I create a rectangular touch pad in Kicad?
Something like this:
Thanks
« Last Edit: August 30, 2020, 04:40:36 pm by redgear »
Offline janoc
Re: How to create a capacitive touch pad in Kicad?
« Reply #1 on: August 30, 2020, 04:36:06 pm »
Create a new footprint and draw this as a pin. There are plenty of options for the pin shape in Kicad.
The following users thanked this post: redgear
Online langwadt
« Reply #2 on: August 30, 2020, 04:37:53 pm »
create a new foot print with one smd pad, shape rectangle with rounded corners
« Reply #3 on: August 30, 2020, 04:40:16 pm »
Thanks....I will try doing it.
Thank you. I cannot use a rectangle, as you can see, the shape is not closed.
Edit: I tried but I am not able to create a shape like the one in the image. I can only create a rounded rectangle footprint.
« Last Edit: August 30, 2020, 04:47:14 pm by redgear »
Online langwadt
« Reply #4 on: August 30, 2020, 05:03:09 pm »
but your drawing is just a rounded rectangle, it just shows the trace connecting to it
« Reply #5 on: August 30, 2020, 05:23:18 pm »
I guess no. This is a Sparkfun breakout board in a different shape. You can see that the shapes do not complete.
Offline janoc
« Reply #6 on: August 30, 2020, 06:36:59 pm »
Of course those shapes "do complete" (are closed). The lines going out of them are traces added after the shape has been placed on the board in order to connect them to the connector/header pins.
I think you should have a look at the Kicad tutorials that show how the PCB layout actually works ...
