Just a plain black box thats quieter than a quiet thing on a quiet night .
Sounds nice. (But that one's too big.)
I've given up, I'll have to make my own.
I'm going for square in two dimensions, that is 13.25" (336.5 mm).
I'll get four sheets of 1/16" aluminum for the sides, the posts are out of 5/8 x 5/8 x1/8 aluminum.
The middle plate that holds the MB gives it some structural integrity.
The top and bottom sides I'll deal with somehow.
I'm looking at maybe 5" (127 mm) on the bottom and about 4" (100 mm) on the top.
Edit: You know, if I switch to an old style ATX with the fan on the intake (instead of a big one on the outflow) I can chop an inch off the bottom dimension and improve the flow.
One morally bankrupt idea that I'm giving up is the idea of L brackets on extension boards.
This whole inset stuff to make L brackets work is just stupid.
I'll just whack the brackets flat so that they can be mounted flat with the outside enclosure.
