Author Topic: How to even start routing this?  (Read 6845 times)
Offline Joanna_HTopic starter
  • Crazy nut case who loves to learn new things.
Re: How to even start routing this?
« Reply #50 on: August 03, 2019, 10:29:31 pm »
Nice thing about the XO2 is it has onboard config memory, core voltage regulator and also an oscilllator, so minimal extra parts. A few package options from QFN32 to QFP144.
Yeah, like the QFP144, enough I/O to get things going..   as I'm trying to create a "modular" cpu that you can see what each bit is doing this could be a nice path.   But I think I'll need a few of them as I'll need quite a few control lines.  Even so, it's worth exploring as an option :D
Offline NivagSwerdna
« Reply #51 on: August 04, 2019, 01:19:20 pm »
I was trying not to mention FPGA as it seemed to go against your design goals and I was assuming this was a 5V retro project.  Checkout TinyFPGA for design ideas if you are going that route.
Mike has replied and has a lot more experience than me but XO2 does come in small configurations or there is ICE40.
Have fun
Offline rstofer
« Reply #52 on: August 04, 2019, 02:37:01 pm »
Back to routing:
If any of the devices are memory chips, you don't have to keep strict alignment between A0->A0, A1->A1, etc.  You can hook the address lines in any sequence.  The only thing that happens is that logically adjacent address are spread around in the memory.
Same deal for data lines.  D0 doesn't have to be right next to D1.
This turns out to be a real big deal when working with memory and MCUs.
ETA:  This may cause problems with DDR memory but is often used for SRAM.
« Last Edit: August 05, 2019, 12:45:40 am by rstofer »
« Reply #53 on: August 05, 2019, 01:38:35 am »
Have fun
Yeah, my original goal was all TTL, but with board space, number of components, etc. etc..  The cost would become silly.
« Reply #54 on: August 05, 2019, 07:01:13 pm »
Thanks for the FPGA suggestion, this is fun.   Different way of thinking about it all, but I should be able to achieve the same goal.   A CPU that you can monitor every part of it and see how it works :D
Thanks.
Verilog is a bit interesting though.......   Something new to learn.
Still, having fun..   AddressLineDriver / Program Counter and a few other bits done so far.
803940-0
The second jump test is an inpage jumping test, which gives a data bus size jump range (16bit in this example) costing only 1 cycle.
« Last Edit: August 05, 2019, 07:03:54 pm by Joanna_H »
« Reply #55 on: August 06, 2019, 05:44:51 pm »
You know the world has become a little scary when you can fit the majority of an old school 16bit processor into about 2% of a low spec FGPA.......
LCMXO2-640UHC-4TG144C. had to choose the 640 as the lower one doesn't have enough I/O pins :/
I'll post no more on this in this thread as I've gone way of topic now.
Online SiliconWizard
« Reply #56 on: August 06, 2019, 07:44:23 pm »
Not surprised. ;D
You did that pretty fast!
Offline PlainName
  • Country: va
« Reply #57 on: August 06, 2019, 08:24:14 pm »
Just like to say that a good habit to develop is to keep pin1 in the same orientation for all chips. Sometimes it's not practical but in that case keeping complete groups the same is a reasonable fallback. Similarly, diodes all point the same way (for those all pointing up/down or left/right). The reasoning is to prevent assembly cockups.
« Reply #58 on: August 07, 2019, 09:09:50 am »
Woops, just noticed I was up all night messing with this.. LOL
Still, have some things now working.
A simple test of a NOP, JMP (in page, LSB only) and LJMP (anywhere in memory, uses both MSB and LSB) was fun.  But starting to eat up those resources as I add more stuff :D
At least the microcode isn't on the FPGA, seperate EEPROM to allow for easy program/reprogram of that little part.  Both memory and eeprom simulated in the testing to see how it's going :D
805047-0
