Author Topic: How to flash a USB flash  (Read 343 times)
Offline ali_asadzadeh
« on: June 15, 2021, 08:25:20 am »
I have a 32GB flash, Unfortunately during a format, flash is not detected by my PC, I think maybe the firmware inside the chip is lost, so do you know any way to re-flash the firmware? I think maybe they have a common chipset and there should be some way to bring it back to life.
I'm a Digital Expert from 8-bits to 64-bits
Offline coromonadalix
Re: How to flash a USB flash
« Reply #1 on: June 15, 2021, 11:04:52 am »
you have tool like :  SD card formater  5.0.1 from Tuxera
a normal format should not brick you usb key   even if its  linux or mac  file(s) format, windows should pop   this device need to be formated  ...
or this usb dongle is sh@%$%  "crap"   I have found in the past  many faked sizes usb dongle, an 1tb size for 8$ usd  lolll  was an 8 gb  loll
For the firmware(s)  you need to know the maker chip inside and if possible to find any related tools for that maker
ChipGenius v4  ....  to identify it if possible
Or see usbdev.ru  website in some cases ...
« Reply #2 on: June 16, 2021, 05:53:07 am »
Thanks for the hint, the flash was working fine and I have used it for several months,
After this last time format, windows can not detect it
it would say this
This device cannot start. (Code 10)
{Operation Failed}
The requested operation was unsuccessful.
« Reply #3 on: June 16, 2021, 05:57:15 am »
ChipGenius v4 report the flash has this info, do you have any Idea what controller it has and how to reflash it?
Description: USB Mass Storage Device
Protocal Version: USB 2.00
Current Speed: High Speed
USB Device ID: VID = 090C PID = 2000
Device Revision: 1100
Controller Part-Number: Unknown
Offline viperidae
« Reply #4 on: June 16, 2021, 06:52:52 am »
Sounds broken.
This website http://usb3speed.nirsoft.net/?vid=2316&pid=8192  shows many different brands and sizes with varying performance all sharing the same vid and pid
« Reply #5 on: June 16, 2021, 07:18:13 am »
Is there a way to flash the chip inside? :-[
« Reply #6 on: June 16, 2021, 09:43:40 am »
You have to find the maker software if there is .... check usbdev ...  sometimes based on the VID PID you can find some hints
