link:
http://www.ebay.com/itm/181769482491?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AITNo datasheet anywhere.
I found it, finally ... ufffff ... in some small old scanned paper from 1970s entitled "calibration of hydrophones".
pC stands for "charge sensitivity" and it is written as 1pC/uPa.
Sq = Sv * (Capacitance of hydrophone + Cable)
where Sq is a charge sensitivity and Sv is voltage sensitivity (V/uPa).
So in my case value 115 Db 1pC/uPa can be translated as V/uPa in dB
10*log10( 10^(115/10) / (11500e-12+1500e-12)) which is equal to
193.86 dB 1V/uPa. Huray!!! unless I made mistake somewhere
Capacity was also given in small spec sheet that I have:
Capacity at 20 °C .... ( at 1 kHz ) .............................. 11500 pF +/- 1500 pFI ignore the cable because spec is for hydrophone without the cable.
193 dB is not bad but not exciting. I found few at 209-216 dB at similar prices.
