I designed the attached input protection stage. I want to make sure it is as robust as possible as if it was designed for safety critical application. So please feel free to highlight any issues with it and suggest any improvement.
Power comes from an external brick-type PSU providing 24V at 10A. 8A are used by another part of the circuit and 2A are used by the regulator shown.
The external brick PSU obviously has its protections but the reason for having this input protection circuit is that - as some of you correctly pointed out in another one of my posts - a user could plug in any other external PSU with higher voltage and/or opposite polarity. This would make sure the system is protected. Again, if even better protection can be achieved please let me know.
These are my consideration for the circuit and for choosing those specific chosen components:
Surge Protection1)TVS D4 has typical failure mode as short under overcurrent or overvoltage conditions. The wording "typical" on the datasheet does not sound "guaranteed" or "certified" to perhaps there are better parts?
2) If the TVS fails short or it causes too high current due to overvoltage the fuse blows. Should the fuse be fast acting or slow-blow?
Reverse Polarity3) I think that is pretty straight forward. Not sure if it can be improved?
Overvoltage Protection4) I am wondering if the values are correct and also whether the Q4 should be a MOSFET or not. Mainly because it could operate in a linear/transition region which could cause the power mosfet Q5 to also operate in the transition region. That could result Q5 to dissipate a lot of power. Is that correct? How can I ensure that Q5 is always either fully on or fully off? Perhaps using a darlington instead of Q4?
Any feedback and suggestions for improvements to make it more robust?
Thank you as always!!
