Efficiency of the TI part looks way lower - about 82% vs. 91% for the ST, based on nearest graphs in the datasheet - ST has a sync. rectifier fet across the diode.
For this application I'm very constrained for space to get rid of heat.
I am not convinced that the ST1S14 has a sync. rectifier FET. The block diagram for the part shows a FET in the sync rectifier position:
But there is no mention of the characteristics of this FET on the datasheet.
The eDesignSuite tool gives diode dissipation that is consistent with no sync FET.
Rectifier dissipation = Vfwd x I x (1 - Vout/Vin)
Assume
Vfwd = 450mV
I = 1.3A
Vout = 13.2
Vin= 48
Rectifier Dissipation = 424mW
No evidence of a sync rectifier.
Regards,
Jay_Diddy_B
