I've been messing with microphone "hummers" used to generate a signal in old bridges. They're quite simple, with a small carbon mic picking up the vibrations of a reed or tuning fork, and modulating the current to keep it going. No tubes, transistors or any other parts, save a transformer to get the right output impedance. The mics are capable of modulating tens of mA, which seems quite remarkable.
Same technology as old telephones that used carbon mics. Reading various things on the 'net, it seems the carbon is anthracite coal powder that's been graded and heat treated, probably to drive off the remaining volatiles. I want to know more specifics- does anybody know the mesh size for the powder, the exact treating process or any other useful info. It seems easy enough to get a chunk of anthracite and DIY your own mic. Also, they are said to slowly wear out. What's the mechanism and the cure? Just shake it up, or does the powder need to be replaced?
