Author Topic: Problem in education FPGA Spartan III board(short circuit the AMS1117-1.2)  (Read 1470 times)
Offline rozehTopic starter
« Last Edit: December 03, 2013, 06:04:51 am by rozeh »
Mark Twain — 'The two most important days in your life are the day you are born and the day you find out why.'
Offline hans
Re: Problem in education FPGA Spartan III board(short circuit the AMS1117-1.2)
« Reply #1 on: December 02, 2013, 05:36:34 pm »
Simple guess: check the soldering?
I note that the via's are placed closely to the QFP pins from the inside. I suspect there is no via tenting applied because I neither see them at the bottom layer. Typically VCC and GND pins are located next to each other, so it is very possible there is short behind the QFP pins somewhere on the board.
Have you checked the pinouts of all components? If one VDD/GND pair is off, you can also see a short on the entire rail.
