you can get some neat connectors which do this BTW. JST make them I think. Depends if there is budget for them. If you butt up well and the boards are mechanically connected to the same chassis I am sure you will be OK; as it's been said it's not the best solution but small boards with good mounting you could get away with it!
Also you need to manually take into account the diameter of the routing bit so the boards butt up perfectly. Then you will be able to solder across; did exactly the same for a small project like this. Put a couple on the bottom as well if you need some mechanical stability.
consider splicng the PCBs using hollow rivets.Rivet the joints and ONLY THEN reflow with solder.This will give you a cheap joint of excellent mechanical strength and an excellent electrical connection.I had used this approach to build a length of approximately 2 meter out of four pieces
Not sure about this. How can we manually take into accoung if we don't know the size of the bit? The PCB fab does calculation so your board is cut correctly even if your board line is 1mil thick.
