Hi All, I am deliberating on what would be the best way to build a simple, MPU-driven ohm and volt meter.
It has to use the same common input for resistance and voltage and a single power supply (max 5V), 1 Ohm accuracy in lowest range, range up to 1MOhms and 100V (AC and DC), 1% accuracy would be sufficient, 0.1% would be perfect.
It needs to be MPU-driven, so no manual range switches etc.
With the right MPU, measuring voltage is not a challenge - even fast sampling and (e.g.) true RMS calculation.
However, I am not sure how to go about measuring resistance. I do not need to measure current.
I would appreciate any hints/advice.
