Author Topic: Crystal Oscillator Layout  (Read 705 times)
Offline luky315Topic starter
  • Country: at
« on: November 17, 2023, 07:31:42 pm »
I am asking myself if it is worth breaking a few "good design practices" like never make a trace leaving a SMD pad with an angle other than multiples of 90° for a shorter trace to the crystal (CFPX-180 package in this case)
It looks a bit wrong and also a bit strange to me using variant 2, so what do you say?
Offline Benta
Re: Crystal Oscillator Layout
« Reply #1 on: November 17, 2023, 09:36:46 pm »
I see no problem with the angles.
But I see a problem having no thermal reliefs on your ground plane. Big potential for bad solder joints.
« Last Edit: November 17, 2023, 09:50:08 pm by Benta »
Offline SiliconWizard
« Reply #2 on: November 17, 2023, 10:08:02 pm »
What difference do you think it will make?
Offline MarkT
« Reply #3 on: November 18, 2023, 09:56:49 am »
The only issue I see is that the 45 degree trace slightly encroaches on the other pad - normally this would be a design-rule error, but here the pad has its corner cut-off which isn't great, not that its an actual problem as its microns.
Its just a crystal, not an oscillator, BTW.
  • Country: at
« Reply #4 on: November 20, 2023, 08:38:51 am »
I don't use thermals on my GND plane for SMD components except on very big inductors and I never had a problem, they are soldered by hand, reflow and even vapor phase.
