Have any of you seen one of these before, whit this style connections for the cable? How do I solder / crimp / whatever the cable to it?
I need to replace the plug on a pair of headphones and the guy at the store offered this "better quality" plug - I didn't really look much and took it as does indeed seem to be better that the others he had; I did not expect the terminals to be like this though, have no idea how to properly solder / connect the cable to it.
Hopefully the pictures are enough. There are little holes beneath the black plastic piece with the metallic rings, one hole beneath each ring, that do not show well in the pictures.
Thanks in advance!
