Author Topic: RF/Microwave experts: Identify these mystery PCB structures  (Read 11440 times)
Offline G0HZU
Re: RF/Microwave experts: Identify these mystery PCB structures
« Reply #25 on: November 28, 2015, 12:32:56 pm »
I had a rummage through some old backups and found a DOS version of Eagleware from 1993. It's version 4.1 and the whole design suite fitted on a couple of 3.5" floppies back then.
This is about the time that =M/FILTER= first appeared and although the screen shot below looks very dated this SW was absolutely amazing back in those days.
The user interface was improved a year or so later but I would have used this old DOS version most days when designing preselector filters for various microwave receivers back then. I haven't tried to use this old version for 20 years but I managed to put together a fairly similar BPF design in the image below. I didn't run the optimiser in the second image showing the simulated response so the passband response is a bit lopsided. The raw filter synthesis tool doesn't produce a perfect filter response even in the later versions of this SW and so it has a manual optimiser feature built in that can tweak/optimise the filter layout for you. I think the optimiser in this version is fairly crude and the later versions have a one touch optimiser button that is well set up in advance to optimise the filter to the basic filter response/ripple requirements.
Note that despite its age, this ancient DOS software uses a crude parallel port dongle for copy protection so I can't give out copies of it.
« Last Edit: November 28, 2015, 12:51:35 pm by G0HZU »
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #26 on: November 28, 2015, 12:50:08 pm »
Ah, cool!
So why can't I have that (and basically identical lumped element functionality) in my PCB design tools  :'( :'( :'( :'( |O |O :-// :scared:
Seven Transistor Labs, LLC
Offline KJDS
    • my website holding page
« Reply #27 on: November 28, 2015, 02:10:45 pm »
Ah, cool!
Because you have bought a cheap pcb tool.
Combine Mentor with ADS or Cadence sprectre RF, but these aren't cheap solutions.
Microwave office and PADS can also be combined
Offline nctnico
« Reply #28 on: November 28, 2015, 03:52:29 pm »
A couple of years ago I have written a small program to convert a lumped element (L & C values) elliptic filter into a microstrip structure. I never got round to add other filter structures to it or include creating the lumped element values in it. There isn't much commercial demand for it.
Offline KJDS
« Reply #29 on: November 28, 2015, 04:45:01 pm »
I did similar for a straight interdigital filter many years ago. It's quite a fun exercise, and with the ease of Sonnet or momentum then it reduces design times significantly.
