Author Topic: How to shield a circuit from noise physically?  (Read 1849 times)
Offline EteslaTopic starter
« on: July 16, 2019, 03:04:35 pm »
Hi all,
I have a sensitive analog circuit on a well laid out PCB that I need to have working in a very noisy environment. Its battery powered. I am going to put that circuit inside of a completely enclosed aluminum housing. My question is this. What electrical connections should I make between the circuit, the box, and the outside world to reduce noise due to EMI from outside elements the most? My gut tells me just connect the PCB ground to the enclosure and all will be well, but I really don't know enough about this stuff. Thanks in advance!
Offline T3sl4co1l
    • Seven Transistor Labs
Re: How to shield a circuit from noise physically?
« Reply #1 on: July 17, 2019, 01:15:35 am »
This is easiest(?) explained through topological transformations.
Uh, well, hear me out, okay?
Start with a sealed metal box.  This is a fine endpoint if you don't need anything into or out of the box -- you can break the seal just ever so slightly with, say, a small opening for optical transceivers (optoisolators, fiber..), and that doesn't really change anything (not at circuit frequencies anyway).
As soon as you stick a wire through such a hole, though... that's a path for noise to travel.  Filter it at the opening, and you prevent interference.
It follows that, for any N wires, you can have N respective holes and filters.  Or you can group the wires together at a common hole, again as long as the hole is small relative to the relevant frequencies, and impedance.
It's usually convenient to have the filters common to circuit ground as well, so you should tie that to the enclosure somewhere inside (and presumably outside as well), in which case ground does not need to be filtered as an independent signal.  (Assuming ground remains ground, of course.  The circuit board should be grounded, early and often, to the enclosure.  Any impedance between the two, and the return currents from all the signal lines flows across that impedance, causing ground-loop voltages and currents.)
There can be [unoccupied] holes in the enclosure, as long as the poorer shielding isn't troublesome.  Say you only need 40dB rather than say 120+ dB.  And that at modest radio frequencies (100s MHz say).  Openings can be a maximum of some cm across.  Such a box may look less like a box, and more like a cube made from angle pieces (plus whatever's supporting the wire feed-thrus, of course).
With these topological transformations, we can start with a closed shield, and open it up strategically, without grossing affecting the electrical performance.  In this way, we preserve important paths and connections, while turning the enclosure into Swiss cheese, or nearly flattening it into a plane.
It is for this reason, that it's very effective to use PCBs with solid ground plane design.  All signals onboard are somewhat shielded by the fact that the board itself is solid metal.  When connectors are placed towards the edge, filters inboard from them, and core circuitry in the center, we can maximize immunity and minimize emissions, by recreating the topology of a box with some holes.
As for signals you can't afford to filter individually -- for example, high speed data -- this can be shielded individually (e.g., coax; the shield should be tied to ground early and often, this sort of thing for example: https://www.harwin.com/product-highlights/smt-cable-clips/ ), or passed as balanced pairs, with common mode chokes to reinforce balance (you're still filtering -- just as a pair together, rather than each wire individually).
Seven Transistor Labs, LLC
The following users thanked this post: Etesla, Wendy_Preston, krayvonk
Offline Wendy_Preston
  • Content Marketing Specialist for Harwin
    • Harwin.com
« Reply #2 on: July 18, 2019, 07:58:35 am »
Just to add to the amazing response from T3sl4co1l - if you want to give some additional protection to any particularly sensitive components on your PCB, we also have at Harwin an EMC Shield Can prototype kit:
https://www.harwin.com/product-highlights/shield-can-kit/
https://www.harwin.com/products/S01-806005KIT/
With this you don't need to try and find a can that's exactly the right size for your components, if you're doing single builds. If you are already putting a ground plane in the PCB, then this might give you that additional EMI protection if you need it.
And this might be worth a watch - our EMC expert did a little talk recently on EMC shielding, might be something helpful in there? I'm not going to pretend to understand it all myself - it's not my strongest subject!
https://www.harwin.com/videos/emc-shielding-designcon-2019/
Good luck!  :-+
Content Marketing and website technical content for Harwin (ex Design Engineer) - contact me on webmaster@harwin.co.uk.
Offline RoGeorge
« Reply #3 on: July 18, 2019, 09:13:16 am »
Apart from the electric fields, magnetic fields can induce unwanted noises, too.  An Al case would make a good shield against external electric fields, but it won't stop much of external magnetic fields from entering into your box.  A layer of mu-alloy sheets (https://en.wikipedia.org/wiki/Mu-metal) might make all the difference, e.g. if the box is near a big transformer.
In domestic environments, most of the induced noise come from the electric fields, magnetic fields are usually small enough to be negligible, unless the electronics are too close to a transformer.  In industrial environments, a transformer or a motor/generator, can be as big as a house, so magnetic shielding might become a must.
